My mate's had a 410 since I put the 2nd 1.3 engine in mine and the 410 engine is still perfect and he thrashes it a hell of a lot more than I do!
Shame about the rust everywhere else
Rhinoman wrote:An SJ413 engine would give a 40% power increase, a Jimny engine would give a 78% power increase and a Swift GTi engine would give a 122% power increase. All those options are also considerably lighter than the 410 engine.
I second this motion. The F10 is happier if you keep the revs up and change at 4/5 thou. From what I gather it sounds like the G13 would rather be up a gear when compared to an F10 most of the time, and if setting off is the problem then you either want an arse-load of torque or lower gearing, not higher.dan_2k_uk wrote:Well the 410 and Sammy gearboxes have almost identical ratios apart from the Sammy having a slightly lower 1st so ithe engine will still rotate at exactly the same rpm to give any given speed but just with an engine that doesent like to rev instead of one that does.
If you don't like screaming a F10 that loves it I don't think you will enjoy belting a G13 at the same revs. The top end will be gutless!
F10A engine:dan_2k_uk wrote: If you don't like screaming a F10 that loves it I don't think you will enjoy belting a G13 at the same revs. The top end will be gutless!
I suggested the 1.2 3 cylinder ali TDI at some point. The 1.4 and 1.9 are heavy - people who've installed them have regretted it, but the 1.2 (inc turbo etc) weighs slightly less than the G13.Edweird wrote:I think Anton was the one that suggested it a while ago, what about a 1.4 diesel from a VW Polo? A lot of people on here view diesel as the fuel of the devil, but I'm not so against it.
