Anybody done the leaf spring over exle convertion?
Josh-holden
Re: Anybody done the leaf spring over exle convertion?
Post by Josh-holden » Sat Nov 08, 2014 12:21 am
At the moment iv got 15". As I'd be doing mostly green lanes I don't want to be spending to much on tyres
Post by ScottieJ » Sat Nov 08, 2014 12:35 am
Josh-holden wrote:At the moment iv got 15". As I'd be doing mostly green lanes I don't want to be spending to much on tyres
That's the wheel size ;) how big do you want the tyres? 235/75r15 (29") / 30" / 31"?
If you are mostly laning the 29/30" should be fine and you don't need much lift to run those, I have 235/75r15s on an Sj with no lift, just a bit of trimming and simple tweaks to the front bumper mounts.
Post by mike harris » Sat Nov 08, 2014 7:56 am
I have landcruiser props on mine, massive wide angle Ujs and there very strong, much more so than an sj prop.
I had to use them as mine on full drop with both missing links open the prop is at a ridiculous angle. And it still works.
Post by donkeychomp » Sat Nov 08, 2014 10:05 pm
Interesting. I bet they don't just bolt on. What mods are needed to use Landcruiser ones?
gamble63
Post by gamble63 » Sat Nov 08, 2014 11:38 pm
what the hell is a virtual lift? haha
Post by donkeychomp » Sat Nov 08, 2014 11:45 pm
Cut out the arches so you have more room for bigger tyres. Not a hard job to do.
gamble63
Post by gamble63 » Sat Nov 08, 2014 11:55 pm
How come people dont just do a body lift?
Post by donkeychomp » Sun Nov 09, 2014 12:50 am
Virtual lift much easier and you retain most of the original looks of the car. A body lift is a pain in the arse on old Suzuki's, for many reasons. First you need a good kit, polyurethane ones are the best and not cheap. Then you have all the seized and rusted in bolts that you'll have to cut/drill out. Takes bloody ages. Then you have to physically lift the body up, not a one man job, put the lift kit in. Maybe add longer brake lines, weld added lengths to gear sticks. What fun. Of course when that is done you have a higher zook which means your handling is VERY compromised. So wider wheels or spacers etc. A lot of time and money is needed.
Virtual lift. Mr Angry and maybe a day if you are cack handed and job done.
Ladaman
Post by Ladaman » Sun Nov 09, 2014 8:38 am
As above.
And the arches probably need repairing anyway, so just do a virtual lift.
Sorted two jobs in one. 8-)
gamble63 wrote:what the hell is a virtual lift? haha
Here is Dan's nice guide on how to do it.
http://forum.suzukiclubuk.co.uk/vi ... =10&t=8046
Post by ScottieJ » Sun Nov 09, 2014 9:39 am
I don't really like body lifts, they reduce the number of contact points between the body and chassis giving it less Suport and increase the stresses on the body mounts. In a bad roll over this could make it more likely for the body to seperate from the chassis.
Especially dodgy box section body lifts, I have seen them after a roll over turned turned into a parrallegogram shape :shock:
