Anybody done the leaf spring over exle convertion?
Josh-holden
Post by Josh-holden » Wed Nov 05, 2014 1:27 am
Hi, just wondering if anyone has done the leaf spring over exle convertion? What do you need to change/ modify?
Ladaman
Re: Anybody done the leaf spring over exle convertion?
Post by Ladaman » Wed Nov 05, 2014 8:05 am
Firstly :welcome: to the club.
And second, why do you want to?
Post by Jordi » Wed Nov 05, 2014 9:00 am
Welcome to SCUK.
Not many fans of Spoa on here, what's the spec of your Zuk and what are your reasons for Spoa?
Post by ROBBIE » Wed Nov 05, 2014 9:01 am
:welcome: and no I havent , wouldn't want to
Post by twiss » Wed Nov 05, 2014 9:06 am
Don't do it unless you want your zook to handle like a top heavy boat!
Post by ScottieJ » Wed Nov 05, 2014 10:52 am
Better to keep it spua with a small spring lift (not shackles) and to do other mods like raising the transfer box to gain a bit of clearance underneath.
Post by Anton » Wed Nov 05, 2014 12:55 pm
I have done an SPOA conversion, and whilst it handles pretty well (not quite "a top heavy boat") it's not as stable as Scottiej's, Twiss's, Dan's and the other guys who stayed with the leaf pack under the axle and did a virtual lift instead.
If I was to rebuild my zuk, I'd go spring under again and virtual lift it instead (cut the arches to fit bigger tyres) like the guys mentioned above. Read their build threads for more info on how that's done. Not rocket science.
I don't think it's any more work to cut/weld the arches than to make and weld on new spring perches.
Josh-holden
Post by Josh-holden » Wed Nov 05, 2014 2:14 pm
hi, thanks for the reply's. iv just brought the truck so i am new to this. the reason i want/wanted to was to lift the springs away from the floor as they are quite low. whats the best way to lift the transfer box? samurai 92. its fairly standard i think apart from its got 15" insa turbos, a roll cage, box section under the sills and its a tray back thats got checker plateon the top. ill get a pic up soon
Post by Anton » Wed Nov 05, 2014 2:19 pm
If you want to lift the transfer case, read scottiej's build thread. It's not the simplest thing to do.
Josh-holden
Post by Josh-holden » Wed Nov 05, 2014 2:24 pm
ok, are they prone to getting hit?
