Suzuki sj 410 from Cornwall PROJECT Never Ending Project
Re: suzuki sj 410 from cornwall PROJECT
Post by turbo-tom » Tue Apr 03, 2012 10:08 pm
looking good :D , give you a tip on your doors , soak the screws with wd40 or some strong fluid apparently diesel works ? , get a shitty screwdrive and chip all the paint around them and start them off hiting a screwdriver in the screw and twisting at the same time if that makes sense?
otherwise your just snap your screwdrivers head clean off ;)
dazerede
Post by dazerede » Tue Apr 03, 2012 10:24 pm
ye chears for the tip got 1 door of with all screws re-usable except 1 screw which i had to grind off, hopefully going screwfix to get some descent bolts to put back on and dont think i want to use these ones on ebay they look smart but might be just as hard to get them undo again
Click Here for Ebay Listing
4” calmini lift kit :)
dazerede
Post by dazerede » Tue Apr 03, 2012 10:35 pm
ye i was using a impact screwdriver which works alright but f**k me aren't they tight they must use some type of locking threads glue or something.
rgonzobull
Post by rgonzobull » Tue Apr 03, 2012 10:36 pm
Looking good! Keep it the good work. It will all be worth it
LJ80Q
Post by turbo-tom » Tue Apr 03, 2012 10:40 pm
yeah the look nice and shiny even though its stainless still they will be buggers probably to get out and even worse its allen key head to be honest i would modify the actually hinge , (one of the clever chaps on her has done it i belive or knows how to!) , were it just lifts of leaving one half of the hinge on the door , the other on the body etc ;)
Post by dan_2k_uk » Wed Apr 04, 2012 12:11 am
Those stainless bolts on ebay are a rip off. I got enough to doo 3 trucks including the smaller ones for the screen to roll bar links on a soft top for less than a tenner.
Seem to come back out easy enough but only time will tell. Anything is better than the originals.
Keep up the good work
Dan
Post by Anton » Wed Apr 04, 2012 11:05 am
Nice build so far! Looking forward to seeing your zuk transformed.
BTW - you're much better at documenting your work than I am... ;)
yellowjeepdave
Post by yellowjeepdave » Wed Apr 04, 2012 9:29 pm
Hey there Daz, nice to see you are getting on with the anus, it is looking brilliant. I sold it to you and just letting you know I am about to embark on restoeing my yellow anus. I will probably try picking your brains on a few points.
dazerede
Post by dazerede » Wed Apr 04, 2012 9:47 pm
nice to see you dave ye truck is going well i thought it would of been easier to swap engines over and put in a descent engine for the meanwhile so i can strip and resemble the old engine and cant wait to get it on the road and meet up again for some green laning and hows your truck doing.
and ye might try and get a spare pair of hinges and make them look like these
http://www.zuk-n-ovations.com/pages/bod ... inges.html
if i do f**k them up i can use me old hinges and buy some bolts to use
yellowjeepdave
Post by yellowjeepdave » Thu Apr 05, 2012 9:53 pm
$239 bit steep for a set of hinges, I have seen it done with the originals they just ground the top off the pin to lift doors on and off. Heres a pic of mine with doors off a couple of years back. http://www.flickr.com/photos/44234282@N06/4759353645/ .........Note the wing mirror bolted onto the bonnet, you will need an offside mirror to keep legal. The bolts on original hinges were pigs and there is nothing behind to really smack the inpact driver, I ended up chiseling mine around untill loose. Hopefully mine will be back on the road before the end of summer.
