Project Bodge
Re: Project Bodge
Post by Jordi » Mon Apr 14, 2014 11:33 am
Looks like nice tidy work bud.
You keeping the 413 diff ratios or going lower?
ferris
Re: Project Bodge
Post by ferris » Mon Apr 14, 2014 6:07 pm
dan_2k_uk wrote:Good stuff.
I need to make a jig just like that to truss mine and add YJ perches.
What size box section is that you are using for that truss. Looks the perfect size.
I used 50mm box section as it's all i had laying around, luckily it fits spot on.
Jordi wrote:Looks like nice tidy work bud.
I'll be using the 413 diffs for the time being. May have to change them at some point if i end up getting chromo shafts or some kind of diff lock in the futuer
ferris
Re: Project Bodge
Post by ferris » Thu Apr 24, 2014 7:14 pm
Finished making the trusses for the rear axle. Just need to weld it all up now. Not sure if iv made a mistake making them to go on the bottom of the axle, as im going to loose abit of ground clearance now.
Re: Project Bodge
Post by Jordi » Thu Apr 24, 2014 7:46 pm
Looks real tidy. Not sure about all the holes in them?
Take it you're just going to spray/pour/force paint into them all when it's welded up?
Ladaman
Re: Project Bodge
Post by Ladaman » Thu Apr 24, 2014 7:54 pm
Jordi wrote:Looks real tidy. Not sure about all the holes in them?
Could you fill it with expanding foam?
That would keep the crap out, or might it hold crap? :er:
Re: Project Bodge
Post by Jordi » Thu Apr 24, 2014 7:56 pm
That would just soak up water, wouldn't it?
I'd of just left it solid and welded it on.
shredder
Re: Project Bodge
Post by shredder » Thu Apr 24, 2014 8:01 pm
paint inside before welding then fire in some waxoil should help
Re: Project Bodge
Post by andyrew » Thu Apr 24, 2014 11:40 pm
Nice work dude.
:doublethumbs:
ferris
Re: Project Bodge
Post by ferris » Fri Apr 25, 2014 8:00 am
I didn't want to keep it as a solid piece because i thought if i didn't fully seal it properly it might fill with water over time and rust from the inside out. I thought if i filled it with holes that 1) i could spray paint in there 2) Any crud would just drain straight back out again. I did intend for the holes to be bigger but i only had a 10mm drill bit.
Re: Project Bodge
Post by ScottieJ » Fri Apr 25, 2014 9:01 am
ferris wrote:I didn't want to keep it as a solid piece because i thought if i didn't fully seal it properly it might fill with water over time and rust from the inside out. I thought if i filled it with holes that 1) i could spray paint in there 2) Any crud would just drain straight back out again. I did intend for the holes to be bigger but i only had a 10mm drill bit.
Buy yourself a cone cutter and it will open up the holes easily enough :thumbup:
You can always jet wash it out through the holes as well. Just take your time welding the truss, it's very very easy to bend an Sj axle case by getting it too hot during welding.
