Project KJA
Re: Project KJA
Post by Anton » Tue Apr 21, 2015 11:35 am
Gocha. So you'd have to rewire them so that the front sidelights come on with the indicators not the sidelights if you went full amber.
And then you'd need sidelights in your headlights or something.
I have actually read that bit of the MOT manual before, for some reason the bit about only having red lights on the rear is the only bit that stuck with me.
ianedwards
Re: Project KJA
Post by ianedwards » Tue Apr 21, 2015 8:08 pm
Sorry should have said, there is side lights in the headlights, I updated them. Oops,
So it doesn't matter if I use the originals or just plane Amber, or led
I'm kinda leaning towards the original ones, not sure why tho..
Just means running a few more wires to get the side lights working again.
Ian. :)
ianedwards
Re: Project KJA
Post by ianedwards » Tue Apr 21, 2015 8:50 pm
as promised a ups guy dropped this off today :)
IMG_3050 (1).jpg (81.95 KiB) Viewed 8461 times
couldn't resist to have gander
now it gets difficult, as i have no power or welder :( its going to take a lot of measuring and drawings, making bits up my dads and then bringing it back to check, I'm a sod for building things and working it out as i go along.
it is a nice winch tho, think it will look good
Ian. :)
ianedwards
Re: Project KJA
Post by ianedwards » Mon Apr 27, 2015 11:49 pm
bit more done, :thumbup:
Ian. :)
Re: Project KJA
Post by donkeychomp » Tue Apr 28, 2015 1:39 am
Very nice work..keep it up!
Re: Project KJA
Post by Anton » Tue Apr 28, 2015 8:26 am
Love the colour!
ianedwards
Re: Project KJA
Post by ianedwards » Tue Apr 28, 2015 10:32 am
hopefully ill get it fitted tonight and get the other one started,
getting the old decals off is a nightmare, heat gun required, need to find it
ford tractor blue :doublethumbs:
Ian. :)
ianedwards
Re: Project KJA
Post by ianedwards » Tue Apr 28, 2015 10:04 pm
update,
managed to track down some nuts to fit the wiper spindles, what a pain that was!
they where to long and had to cut them down but they are fine.
wipers fitted and working great, even had a bit of a test. also fitted the washer jet as i lost it, had to take the gauges and vents out to get at it, my fault
door on, looks good i hope, just got to change the bolts on the door for stainless ones, to match the ones in the wing, but it started raining :(
not too bad,
just waiting for some new clips to come for the door cards, a few seem to be missing.
but coming along nicely, quite chuffed
:salute:
Ian. :)
Re: Project KJA
Post by donkeychomp » Wed Apr 29, 2015 1:05 am
Can you get a close up pic of the switches you have mounted underneath the air vent. That does look interesting.
ianedwards
Re: Project KJA
Post by ianedwards » Wed Apr 29, 2015 7:20 am
yea sure, will do after work.
Ian. :)
