Page 57 of 97
Posted: Thu Sep 26, 2013 8:29 pm
by Anton
Ah, so the rear (which may have the bits that are sammy compatible) aren't high pignon?
Shame, never mind. Maybe instead, Mike should just get a set of C303 axles...
Posted: Thu Sep 26, 2013 9:15 pm
by mike harris
Yeh jimny parts are made from davidstowe cheese. Taste nice, not to good when running boggers !!
No panic, il run the same as before, just stronger.
If these break well il be on the look out for something mad, and il sell all my axles and spares I have for them too.
Mike
Posted: Mon Sep 30, 2013 10:37 pm
by mike harris
5 day weekend coming up boys !! Brace your self people !!
Mikes on mission !!
I when all which I need now, even the 2 pack paint to paint the axle, rear winch is so nearly finished, two more welds to run !!
Posted: Tue Oct 01, 2013 9:45 am
Just read the last few pages for a bit of catch. Looks like you'll be having a mega weld-a-thon on that front axle.
Posted: Tue Oct 01, 2013 1:09 pm
by mike harris
Yeh it well not bend but will weigh 4 times what a standard one does lol !!
Posted: Tue Oct 01, 2013 4:08 pm
by Anton
Adding weight below the vehicles centre of gravity isn't necessarily a bad thing, though...
And it's not a heap of weight. It'd probably ride a little bit more crap on the road, but yours is not for such misadventures - yours is for the mud, where zuks belong...
Posted: Wed Oct 09, 2013 7:30 pm
by kiwizook
updates?
Posted: Wed Oct 09, 2013 10:54 pm
by mike harris
Hello,
Sorry erm not much to update really, been busy with work.
Rear winch is all welded in now. Just needs painting and wiring up and a second battery fitting.
Old front axle is out, cut all the old trusses and diff guards of it, new axle mocked up with new saddle and trusses, just tacked into place for now. Little bit of mucking about to make the of side truss fit in the bottom, as its so short and has to wrap around the Rockwatt knuckle gussets. Which is proving to be a bit tricky.
Should get some time weekend after next to do some more, it's time I need and there's not enough of it !!
Still need to get some side gears to do my diff with, I have had my diff builder build suzuki diffs for other people and not had my own done yet !!
But anyway, onwards and upwards lads
Posted: Wed Oct 09, 2013 11:02 pm
I might have some 26spine side gears if you need some?
Posted: Wed Oct 09, 2013 11:06 pm
by mike harris
Do need some and I have no rear diffs left :(
Il text you in the morning mr Scottie
