sticking throttle and stiff throttle cable
george123
Post by george123 » Tue Mar 18, 2014 8:50 pm
hello I was driving my sj down the road today after doing the ignition timing and trying to pick up speed and the throttle is really stiff to press down? and also it tends to stick a little bit around 2500 rpm any idears?
thanks
Re: sticking throttle and stiff throttle cable
Post by twiss » Tue Mar 18, 2014 8:55 pm
I would feel what the throttle arm on the carb feels like.... if it doesn't stick when you do it by hand you know its not the cable or pedal
If its the pedal WD-40 helps :)
If its the throttle arm itself use carb cleaner on it :)
george123
Post by george123 » Tue Mar 18, 2014 9:09 pm
okay cheers mate :)
