bump stops!
soalsix
bump stops!
Post by soalsix » Sun Apr 20, 2014 12:59 pm
All 4 bump stops have come off the Sammy. What do you guys do to replace them? Genuine? Or use something like land rover stops?
Re: bump stops!
Post by twiss » Sun Apr 20, 2014 1:13 pm
lol how did the back ones come off they are attached under the axle u-bolts :P
I'm running standard ones extended with box section
I was looking at ford escort rear axle bump stops as they look about the right size and shape and you can get them in poly :)
dazerede
Re: bump stops!
Post by dazerede » Sun Apr 20, 2014 2:26 pm
Twiss the rubber is only glued on to the metal my rears have come of loads of times tempted to use my spare fronts and bolt to the rear
4” calmini lift kit :)
soalsix
Re: bump stops!
Post by soalsix » Sun Apr 20, 2014 3:58 pm
The rubber bits are gone..... I actually have no idea!! Lol. I'm gonna need something cause my standard shocks bottom out. I'll have a look at the escort rears. Cheers
Re: bump stops!
Post by twiss » Sun Apr 20, 2014 10:01 pm
Ahhh right never managed to rip one of mine off!
If you did the escort ones you'd have to mount them to the bits the rear ones normally bump into as they aren't like the standard ones
chef
Re: bump stops!
Post by chef » Sun May 11, 2014 11:38 pm
hi it happen to mine as well. both of them at the rear gone.... you can find some easilly if you key suzuki bump stop in your search engine. I am going to put a leaf over axle kit so will need different ones.
kibris
Re: bump stops!
Post by kibris » Mon May 12, 2014 9:17 am
I have defender ones on mine - loads cheaper!
soal6
Re: bump stops!
Post by soal6 » Sun May 18, 2014 9:44 pm
I've now got morris minor rears and series 2 fronts on mine now. The grand sum of £25 new for all 4
