while at compton bassett i hit a mud run a bit quick and the snorkle was not sealed properly i reakon i took a load of sandy water through the su and have damaged the piston rings dose anyone know if wynns smoke stop works it smokes more than me at the mo
cheers phill
scott you still got that anus
smokey engine
Re: smokey engine
yeah i have still got the sj but i foolishly said my missus can have it
is it a 410 you've got? if so i have a spare bottom end you can have for a good price! also got some valve stem oil seals as they could be why its smoking!
Re: smokey engine
if its a 413 i think i have valve stem seals somewhere. might be worth a try b4 doing anything bigger
Re: smokey engine
cheers all it does not do it when its cold only when its hot thats why i reakon it is the rings i have a couple of spare engines but dont want to go down that route until it dies its only a off roader not my daily drive (well you will see how rough it is at the weekender) all i really want is a quick fix
cheers phill
thanks scott let me know if you have any cheap ones
cheers phill
