carby problem?
carby problem?
gday every1....got a problem with the running os my sj413...when ya put revs on it just cuts out as if no fuel is getting through....when the fuel line to the carbi is disconnected fuel pumps out of the pipe...when the pipe is connected to the carbi the fuel filter empties but the pump still runs.have a got a blockage somewhere and what fix do you recommend..cheers
Re: carby problem?
Try running it without the petrol cap. If it works fine they you probably have a blocked tank breather hose
Re: carby problem?
will give it a go and let ya know cheers
Re: carby problem?
Gday Twis cheers for ya advice....seems to have sorted the problem out ...carby is still gonna get a good clean out too...rough country over here in nz...cheers mate
