samurai vitara exhausts
mk1joe
Post by mk1joe » Wed Oct 15, 2014 6:34 pm
Hey guys,
been a while since ive been here, hope everyone is well!
Quick question... is there much difference between the 8v vitara exhaust and the 1.3 samurai exhaust?
ive got a 1.6 8v in my samurai at the moment but I have the standard samurai exhaust. is a vitara exhaust much bigger? would there be any advantages? is it worth me putting a vitara exhaust on it?
Thanks very much!
Re: samurai vitara exhausts
Post by Jordi » Wed Oct 15, 2014 6:37 pm
Presume a vit exhaust is routed / bent differently to match the vits shape.
mk1joe
Post by mk1joe » Wed Oct 15, 2014 8:09 pm
Do you reckon the pipe is a bigger diameter?
Post by Jordi » Wed Oct 15, 2014 8:57 pm
That I have no idea.
Post by dan_2k_uk » Wed Oct 15, 2014 9:32 pm
Yeah I think so. I just made a bigger one. Seems to work well. SJ exhausts are small.
mk1joe
Post by mk1joe » Wed Oct 15, 2014 9:45 pm
thanks mate, im thinking of doing a bit of an unconventional exhaust modification as a bit of an experiment. will let you know if it works.
what diameter do you think an sj exhaust is? I would measure mine but I don't have the car to hand at the moment.
Post by donkeychomp » Wed Oct 15, 2014 10:13 pm
Standard Vit zorst is about 10mm wider than an SJ one. Bung a cherry bomb on it...
mk1joe
Post by mk1joe » Wed Oct 15, 2014 10:23 pm
Oh yea! I forgot about cherry bombs.
Might do...
Post by twiss » Wed Oct 15, 2014 11:51 pm
I noticed quite a bit of difference just with an uprated rear section...
reducer welded backwards to what was left of the flange end of the rear section
1.5" pipe with a cherry bomb on the end... 1.5" inlet, 2.5" outlet
With the 16v I had to make the exhaust from scratch, using the top part of the 16v downpipe for the flange, to 2" bent pipe, to 2" inline cherry bomb, flange, 2" straight-ish pipe > cherry bomb w chrome tip
final cherry bomb is 2" inlet 3" outlet
its bloody loud!
mk1joe
Post by mk1joe » Thu Oct 16, 2014 7:58 pm
Thanks guys, I definitely need to do something with the exhaust then! I will let you know how it goes. I intend to update my build thread when all the mods are done:)
