g13a carby
kdalton
g13a carby
Post by kdalton » Mon Feb 02, 2015 9:48 am
can anyone tell me what brand this carby is.im using a lot of fuel.any tips. when I start up in the morning the auto choke dosent seem to rev the motor and then cut off when engines warm.its like the valve in the carby is allways closed. thanks
Ladaman
Re: g13a carby
Post by Ladaman » Mon Feb 02, 2015 10:50 am
To me it looks like the hyper over complicated standard Aisin carb.
Change it!
Re: g13a carby
Post by Anton » Mon Feb 02, 2015 1:48 pm
If that thing is causing problems, there are tricks you can use to get it running properly again. But most of us swap it for either an SU HIF44 side draught carb or a webber.
I have an SU. A bit more power, possibly a bit more MPG's, smooth running and a lot less hassle. The most hassle I have is forgetting to pull out the choke. It literally starts on the button if I have the choke cable set appropriately to the engine temp.
Can't really comment on the Webber, although doubtless it gives more go. It's kinda what they're famous for!
kdalton
Re: g13a carby
Post by kdalton » Tue Feb 03, 2015 4:59 am
so would the su hif 44 bolt straight on and any wiring need to be done.thanks
kdalton
Re: g13a carby
Post by kdalton » Tue Feb 03, 2015 7:44 am
what the advantage of a su hif44 carby on my g13a motor.were do I get the conversion or adapter plates.thanks
Re: g13a carby
Post by Jordi » Tue Feb 03, 2015 11:27 am
You need an elbow adaptor (cheap and cheerful off ebay).
Or a modded manifold, approx £125 from RockWatt.
To fit the HIF is a few bolts, breather pipe, fuel in and fuel overflow. All the exisiting wiring just needs putting neatly out of the way.
Depending on the set up of the HIF you buy it might need the needle and spring changing.
Plenty of threads on here with more info and pics.
Re: g13a carby
Post by ScottieJ » Tue Feb 03, 2015 12:19 pm
Being in Australia I'm pretty sure there's some other popular carb options as well.
Might be worth having a search on www.auszookers.com :thumbup:
Re: g13a carby
Post by Anton » Tue Feb 03, 2015 2:56 pm
Yeah, if you're in Aus then an SU carb is probably not the way to go. They're everywhere in the UK, I doubt they're as popular elsewhere - they came on just about every Brit car going from the Mini to Jaguars and Range Rovers, they were simple and robust - meaning there are still loads about that outlived their car.
I have no real idea, but I don't *think* you'll find many your end of the world. If I'd known you were in Aus I wouldn't have suggested an SU, as I don't think it'd be simple to get needles, springs and seals or refurb kits for them down there even if you can lay your hands on an actual carb. I think it makes sense to use parts that are easily serviced and easily replaced.
Re: g13a carby
Post by ScottieJ » Tue Feb 03, 2015 4:43 pm
A common swap there is a 4K corolla carb I think
