LARGE SWIVEL BALL JOINTS SJ413 SAMURI
basil
Post by basil » Fri Feb 27, 2015 3:34 pm
Have always lubricated the balls with silicon spray......what do others recommend / use on theirs ????
Jim......
NylonAdmiral
Re: LARGE SWIVEL BALL JOINTS SJ413 SAMURI
Post by NylonAdmiral » Fri Feb 27, 2015 3:38 pm
How do you mean? Like sprayed the ball which the swivel seal seals against?
I'm sure someone will correct me if I'm wrong but I don't think these particularly need lubricating?
The seal is essentially there to keep debris out of the inside of the steering knuckle I think?
Post by ScottieJ » Fri Feb 27, 2015 4:07 pm
Most people lube them with leaking inner axle oil seals :lol:
NylonAdmiral
Post by NylonAdmiral » Fri Feb 27, 2015 4:10 pm
LOL, yeah it doesn't take long before they start to self lubricate...
basil
Post by basil » Wed Mar 04, 2015 12:13 pm
Just cleaned and lubricated the swivels with silicon grease.....no sign of leaks glad to say @ 94,000 miles
jim
NylonAdmiral
Post by NylonAdmiral » Wed Mar 04, 2015 12:26 pm
Nice, although I'd be astonished if one set of axle oil seals have lasted 94,000 miles! :jawdrop:
Post by ScottieJ » Wed Mar 04, 2015 12:47 pm
Just wait until it's put in 4wd :lol:
basil
Post by basil » Wed Mar 04, 2015 3:12 pm
I only put it in 4 wheel drive when i bought years ago so as you say it would probably leak if used thus
i did replace the gaskets that keeps dirt out of the swivels about 5 years ago ......probably needs doing again now.....
jim
Post by ScottieJ » Wed Mar 04, 2015 4:46 pm
I'm sure it will be fine, the swivel seals/gaskets are only there to keep mud and water out, it's the inner axle oil seal that can fail and allow diff oil into the knuckles. When it's kept in 2wd and if it has free wheeling hubs fitted then the axle isn't spinning in the seal so it's less likely to leak even if it's gone hard.
