Grand vitara steering damper
Rodden87
Post by Rodden87 » Mon Mar 02, 2015 9:12 pm
Anyone know of any steering damper kits for a grand vitara? I have found kits for vits anyone know if they might fit a gv
W reg jimny, 31" trekker on 15x8 mods, ora 4.5 lift, poly bushed, pro-comp shocks, braided brake lines, sj 410 transfer box with 6.5.1 tg gears, KAP stainless exhaust, custom snorkel and extended arches!
Re: Grand vitara steering damper
Post by Darrell » Mon Mar 02, 2015 10:30 pm
I'm confused, GV = Power steering and rack & pinion :er:
Post by ScottieJ » Mon Mar 02, 2015 10:32 pm
There isn't one as you don't need one :thumbup:
Rodden87
Post by Rodden87 » Mon Mar 02, 2015 11:25 pm
Cheers chaps, the reason I want one is I get quite a bit of wheel wobble at about 50mph, it's currently running 3 inch lift springs that I'm changing for 2" to help the angles out! I'm going to look into getting tires rebalanced as I can't find anything else that would be doing it!
Post by ScottieJ » Mon Mar 02, 2015 11:28 pm
Get the tracking checked, it should have been adjusted when it was lifted so this could have caused quite a bit of tow in and that can cause instability and death wobbles.
Rodden87
Post by Rodden87 » Mon Mar 02, 2015 11:39 pm
Cheers Scottie will do.
1995 Zuk
Post by 1995 Zuk » Tue Mar 03, 2015 3:20 pm
are there camber adjustment bolts fitted??
2003 GV1600 sport
1995 Vitara SWB
Rodden87
Post by Rodden87 » Tue Mar 03, 2015 4:34 pm
Yes but its got a 3 inch lift and I don't think the bolts are quite enough! I've ordered some 2 inch lift springs hoping they should improve things!
