How do I tell what engine is in my truck
Josh-holden
Post by Josh-holden » Mon Mar 16, 2015 1:40 pm
Hi, iv just brought another sj. How do I tell what engine it is? He said it was a vitara 1.6? The reason being is I need to order some bits for it.
Re: How do I tell what engine is in my truck
Post by twiss » Mon Mar 16, 2015 1:43 pm
It will have the engine size in CC stamped onto the side of the engine near the gearbox timing hole on the passenger side.... vitara 1.6 will say 1590cc
1.3 will either be 1298 or 1324 depending on the age of the engine
Josh-holden
Post by Josh-holden » Mon Mar 16, 2015 1:53 pm
Ok thanks for that. I knew I had seen it somewhere. It's got 31s on it and is supposed to have a rock lobster box in, I don't think it has, what's the easiest way to tell?
Post by twiss » Mon Mar 16, 2015 1:56 pm
take the rear prop off, and either take the front off or unlocks hubs... then put gbox in neutrol and turn the input flange to see the 4L ratio of the input shaft to the other shafts
Josh-holden
Post by Josh-holden » Mon Mar 16, 2015 2:02 pm
Ok, what should it be?
Post by twiss » Mon Mar 16, 2015 2:07 pm
Josh-holden
Post by Josh-holden » Mon Mar 16, 2015 2:43 pm
Just looked and it is 1590. Am i right in saying its the 8v as it has a carb? How do i go about ordering parts? How can i tell the age?
Post by dan_2k_uk » Mon Mar 16, 2015 3:10 pm
Probably although some people convert SPIs and use and electrical pump. Does it have a mechanical pump on the head?
Josh-holden
Post by Josh-holden » Mon Mar 16, 2015 3:41 pm
No electric
daemon982
Post by daemon982 » Mon Mar 16, 2015 3:43 pm
I would say you have a 8v G16A type of engine as i do. Mine is 1991.
The Vitaras with carb were made from 88 onvards to 98.
someone correct me if i'm wrong.
You also have a type of engine mark on engine itself.
