Rear axle oil seal?
Matt
Rear axle oil seal?
Post by Matt » Tue Apr 14, 2015 8:02 pm
The rear axle oil seal went on my 410 at the weekend so I've ordered a new seal along with a new wheel bearing, is it easy enough to do at home? Or do I need a press etc?
1987 - Suzuki sj410q
31" Maxxis MT764 Bighorns
Winch & winch bumper
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
http://www.youtube.com/user/Matt270498
Re: Rear axle oil seal?
Post by ScottieJ » Tue Apr 14, 2015 8:18 pm
http://www.suzukiclubuk.co.uk/diy/18-wh ... l-bearings
I've always just tapped the new bearings and locking collar on with a bit of tube that perfectly fits over the shaft and only makes contact with the centre of the bearing.
Matt
Post by Matt » Tue Apr 14, 2015 8:34 pm
Thanks Scottie that's perfect 8-)
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
Post by Jordi » Tue Apr 14, 2015 8:38 pm
Easy enough at home. Presuming you have a slide hammer to get the shaft out.
I cut the old collar off carefully with a grinder and used that to tap the new bearing and collar on.
Matt
Post by Matt » Tue Apr 14, 2015 8:57 pm
Cheers jordi, il be having a go at it one evening this week
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
Post by twiss » Sat Apr 18, 2015 4:14 am
Just a quick one... I have part of a rear brake drum (the center bit) that I was going to use for a rear disc conversion.
When bolted onto the halfshaft it makes removing the shaft really easy with a hammer using the clock face method!
lukey4x4
Post by lukey4x4 » Mon Jul 20, 2015 12:46 am
hi just wondering does the link u put on for the rear wheel bearings n seal part numbers do they fit all years of sj axels and is there a site I can order from thanks
Post by dan_2k_uk » Mon Jul 20, 2015 11:52 am
They are all the same. Just order from any motor factors. I've had a few kits from Euro Car Parts and they've always been SKF.
lukey4x4
Post by lukey4x4 » Mon Jul 20, 2015 4:26 pm
Thanks dan just got my mate from local car garage to order some for me £20+ vat not to bad
