Fuel tank pipe connector?
gamble63
Post by gamble63 » Sun May 10, 2015 6:59 pm
Hey guys ive lost or cant remember what connector comes off the fuel line in the tank and how it then connects to the fuel line:
what would you guys do? or where would i get a replacement?
Re: Fuel tank pipe connector?
Post by andyrew » Sun May 10, 2015 7:06 pm
It's a solid pipe that bolts on. Mine was rotten
So I just cut the union of the sender
And ran new rubber hose instead.
Post by Jordi » Sun May 10, 2015 7:10 pm
I cut the threaded joint off and fit braided rubber fuel hose from the tank all the way to the fuel pump.
gamble63
Post by gamble63 » Sun May 10, 2015 10:16 pm
Awesome, i cant afford to re run the lines with braided, i only need a small piece to go from tank to the original pipe work.
Thanks for the idea guys !!!
Post by Jordi » Sun May 10, 2015 10:20 pm
Cotton braided rubber pipe. Nothing flash. Few quid on ebay.
gamble63
Post by gamble63 » Sun May 10, 2015 11:15 pm
ah thought you ment the flash steel braided hose etc.
hahaa
Post by Jordi » Mon May 11, 2015 12:02 pm
gamble63 wrote:ah thought you ment the flash steel braided hose etc.
hahaa
Ha ha, nah, ebay special. Seems to be fine.
