flatspot
kdalton
flatspot
Post by kdalton » Tue Aug 04, 2015 8:44 am
sierra 1.3motor.after 4 months ive got a flatspot when taking off.any tips to fix it. cheers
kdalton
Re: flatspot
Post by kdalton » Tue Aug 04, 2015 10:53 am
come on guys just because you won the cricket last week you can still answer an aussie
Re: flatspot
Post by ROBBIE » Tue Aug 04, 2015 11:41 am
What carb is on it?
kdalton
Re: flatspot
Post by kdalton » Tue Aug 04, 2015 11:51 am
standard aisin carb
courior
Re: flatspot
Post by courior » Tue Aug 04, 2015 7:55 pm
Apparently the choke flap/butterfly can get loose on them and not work well.
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: flatspot
Post by Jordi » Tue Aug 04, 2015 8:47 pm
Bun the carb. Get a replacement. Webber or SU.
Re: flatspot
Post by donkeychomp » Tue Aug 04, 2015 10:01 pm
I do like Jordi's idea but you could always strip and clean it...
Re: flatspot
Post by dan_2k_uk » Wed Aug 05, 2015 11:35 am
They are famed for problems with the auto choke and idle up systems.
The easy option here is to fit a HIF44 SU but may not he so readalily available where you are.
As said check the choke flap isn't loose or sticking.
Check for air leaks or cracks in a vacuum pipework.
