New Member in Gloucester
Bondurat
Post by Bondurat » Sat Oct 31, 2015 10:22 pm
Hi Guys,
Been a member for a couple of weeks but only collected the car this weekend. I'd like to find out if there are any member in Gloucester that wouldn't mind me having a look under the hood of their Zuki.
My car needs a new starter motor fitting (which I have) but I want to check how to wire it up properly so thought the easiest way was to look at another car and copy that. Starter has two connections but so far I've found 3 large cables 1 Poss, 1 Neg from Battery and 1 Earth bolted to body.
I think the poss goes to the connection closed to battery, but to both neg/earth go to the terminal closest to the engine block?
Mine is a 92 Samurai 1.3
Appreciate any members close by that would allow me to have a quick look....
Cheers Guys.
:rhinohump:
My new toy ;-)
My new toy ;-)
Re: New Member in Gloucester
Post by dan_2k_uk » Sun Nov 01, 2015 12:21 pm
The positive goes on the empty terminal post on the solenoid on the starter. Any grounds just go to the bottom bolt where the starter bolts to the gearbox. Then there is just the trigger wire to plug on to the little spade terminal.
Welcome to the club.
Post by ROBBIE » Sun Nov 01, 2015 1:54 pm
Hi :welcome:
Post by Anton » Sun Nov 01, 2015 3:04 pm
Post by Jordi » Sun Nov 01, 2015 6:34 pm
Martin86
Post by Martin86 » Mon Nov 02, 2015 11:26 am
Hello from Suffolk :hands:
Post by twiss » Wed Nov 04, 2015 3:07 am
Hi and welcome to the forum!
Dan has hit the nail on the head.
However, I would add that I prefer to connect the earth to the top bolt starter motor bolt rather than the bottom one.
The top one bolts through and has a nut so you can do it up really tight to make sure you get a good connection.
The bottom one screws into a threaded hole in the gearbox and it isn't massively difficult to strip the thread out accidentally!
