Magnetic diff oil plugs
Is there such a thing for the sj? I've just spent a good hour cleaning out an axle with petrol, rags, compressed air and a magnet after we blew a diff to bits and it's as clean as il get it, just wondering if there is a magnetic plug available for piece of mind, if hate to damage the new diff and we drove home a few miles after it happened with the prop shaft removed so there was a fair amount of small particles
Re: Magnetic diff oil plugs
My standard ones are magnetic.... the front axle one had all sorts of metal bits attached to it from my last front diff explosion
Pulled the plug on our spare front axle and it is magnetic, strange the rear isn't maby it's gone walk about
Check that the filler and drain aren't swapped over.
