Hi there,
I am totally new to owning a SJ 413. The mechanic here in Cape Verde speaks little english and has told me there is a problem with the segment? I have no idea what this is and what i need to get in parts to fix it. Any help would be appreciated and any parts needed where can i get.
thanks
Jonathan
Segment????
Re: Segment????
I have no idea what this is can you get a pic of it?
Re: Segment????
it is apparently a ring that is failing and leaking oil into the engine and causing low pressure...make any sense?
Re: Segment????
Could be a piston ring but it would be expensive to buy some to find out it was something else he needs and its got lost in translation.
Re: Segment????
You seem to have 2 threads running for the same problem...
