Factory Service Manual for a 1989 SJ 410 Santana
HuwJones
Post by HuwJones » Mon Feb 08, 2016 5:49 pm
Hi Guys,
I'm looking for a service manual for a 1989 SJ 410 Santana. Does I've seen one for a early SJ 410 and a SJ 413 but can't seem to find one for the later SJ 410s.
Thanks
Huw
There's three ways of doing things,
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
Re: Factory Service Manual for a 1989 SJ 410 Santana
Post by ScottieJ » Mon Feb 08, 2016 6:00 pm
Just use the 413 one here, http://forum.suzukiclubuk.co.uk/vi ... =16&t=2103 it doesn't cover the engine but everything else is pretty much the same. Pretty sure most 410 ones have a supplier menus section in the back and tbh the only major difference is the front hub/brake set up, all the info for that is on here so that's not too much of an issue.
you can find pretty much all the engine specs and clearances etc on the forum as well.
I've just got a 410 and a samurai service manual in the workshop, covers everything ill ever need.
