Performance
Golfinggas
Performance
Post by Golfinggas » Fri Jul 21, 2017 11:59 am
Does anyone know the pulling power of a Jimny in 4wd low ratio?
Regards Golfinggas
Online
Re: Performance
Post by Jordi » Fri Jul 21, 2017 11:51 pm
As in it's max torque? Weight?
zook123
Re: Performance
Post by zook123 » Mon Jul 24, 2017 8:17 am
If it's towing on the road, 4x4 Low cannot be used... and the towing capacity is 350kg unbreaked, 450kg breaked.
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Online
Re: Performance
Post by Jordi » Mon Jul 24, 2017 9:22 am
zook123 wrote:If it's towing on the road, 4x4 Low cannot be used... and the towing capacity is 350kg unbreaked, 450kg breaked.
According to Suzuki for the latest generation it's 350kg unbraked and, not that you would want to 1300kg braked.
4wd low makes zero difference to this. The 4wd system is only designed to be used on loose and slippery surfaces. If used on dry grippy surfaces like tarmac it winds the transmission up and will ultimately cause issues.
Re: Performance
Post by ScottieJ » Mon Jul 24, 2017 9:47 am
Online
Re: Performance
Post by Jordi » Mon Jul 24, 2017 10:33 am
I'd say that was impressive but i've seen a human pull more.
zook123
Re: Performance
Post by zook123 » Mon Jul 24, 2017 10:44 am
Mine struggled to pull a Ford Focus along a flat road, saying that, that was on the old engine
