410 to Samurai axle swap
Matt
Post by Matt » Sun Dec 24, 2017 7:14 pm
In the new year il be putting samurai axles on my 410, whats the easiest way to move the perches on the samurai axle? i would like to do it as properly but efficiently as i can.
Matt
1987 - Suzuki sj410q
31" Maxxis MT764 Bighorns
Winch & winch bumper
LED light bar
Safari snorkel
Mk1 golf headlights
Bucket seats
http://www.youtube.com/user/Matt270498
Re: 410 to Samurai axle swap
Post by Anton » Sun Dec 24, 2017 9:12 pm
When I swapped in Sammy axles to my 413, I cut the old ones off and made new ones out of box section. 3 of them are identical, but the one that rides the front diff pumpkin needs one side expanded to match the curvature of the diff pumpkin.
Post by ScottieJ » Mon Dec 25, 2017 12:47 am
Either cut the old ones off as carefully as possible and re use them, the front diff side as mentioned above will need tweaking with a grinder. Or make new perches out of 2” 3 or 4mm box and weld them on, easiest way is with a 64mm hole saw.
You need to move each perch in 40mm
Post by mike harris » Mon Dec 25, 2017 8:35 am
Could get some low range perches and fit them?
Just an idea mattew, I've always wondered if you could use an sj413 case, then modify the housings like make a hybrid one with a bit of both. But I'm sure that would be loads of work !
Let me know if you want some original perches I can take some of the axles I have if that helps.
You've helped me more than enough times in the past few years lol
Mike :)
marve114
Post by marve114 » Tue Dec 18, 2018 10:37 am
Time to revive an old thread as I’d like todo this any issues on the different diff ratios with the 410 ?
Any body good at making perches ??
And pictures guys
Post by mike harris » Mon Dec 24, 2018 11:05 am
Matt is doing this at the same time he's not far from you,
Maybe when his is done he can advise you.
Post by ScottieJ » Fri Dec 28, 2018 11:52 pm
as long as your tyres aren't too big it should be ok on the Sammy ratio diffs, however its not hard to re gear, then again if you do fit a 1.6 you won't need to worry about stock diff ratios up to 31" tyres with the 410 tbox.
