G16A rebuild
G16A rebuild
Hi, I have swapped the block on my 1.6 8v vitara and rebuilt top. Turns over great but will not fire. I am going to have no hair left with the timing on this thing. Any ideas?
- timwilks13
- SCUK Website Padawan
Re: G16A rebuild
Go through the check list, do you have a spark? Is fuel getting to the engine? If so the timing could be out, commonly 180° out, but check the first things first.
Re: G16A rebuild
Thankyou
I do have spark and can smell fuel but not 100% fuel lines round carb/pump are correct.
Cannot find decent picture which shows this.
Can you suggest a site.
Thanks
Stew
Thanks
Stew
Re: G16A rebuild
Right up and running
New problems are
No reverse lights
High revs
Heating rubbish
New problems are
No reverse lights
High revs
Heating rubbish
- timwilks13
Re: G16A rebuild
No reverse lights, check all your earths are solid and not rusted or loose, check the reverse switch on the gearbox doesn't have snapped wires etc.
What carb are you running?
Whats wrong with the heating? Check the heater matrix is not blocked or any of your air duct pipes haven't come undone under the dash maybe.
Re: G16A rebuild
Sound new Japanese thermostat sorted heating out toasty. My mate took reverse switch apart and cleaned it,all working.
It's running Makuni carb.drives but very rich and high revs. Going to try tamper proof setting tomorrow.
Re: G16A rebuild
Downloaded Rhinoman.org the original vitara workshop manual. It tells you everthing
Re: G16A rebuild
I found that using the "colourtune" kit from Gunson let me tune my SJ's carb pretty much perfectly. Got much better fuel economy when I was done, although I didn't feel any more power, probably because I was running rich before.
Have you put a timing light on it and sorted the timing?
