Mud tires question
ThomasSJ410
Mud tires question
Post by ThomasSJ410 » Mon Jan 06, 2025 12:09 am
Hi, how big tyre can the sj410 engine take? No other customizing other than ome spring and shocks and a small shackle lift
Re: Mud tires question
Post by ScottieJ » Mon Jan 06, 2025 12:57 pm
I probably wouldn’t go bigger than 235/75r15
It will struggle a bit on road on hills but the little f10 loves to scream at high rpms so it’s fine 😅
I ran a 410 with 30” tyres for a few years and it was fine.
Also bin the shackle lift and refit standard shackles, longer shackles do more harm than good on and off-road and the tiny amount of lift they give will not provide any benefit to your SJ.
ThomasSJ410
Post by ThomasSJ410 » Mon Jan 06, 2025 1:42 pm
Thank you Scottie
I am searching for a post i believe i saw from you, but i cant find. It was about how to tell the difference between type 1 and 2. Mine has steel dash, disc brakes in front and 4wd light in dash. I believe i read that was type 2? Is it so that the 413 gearbox will fit, so i can swap to g16a?
Post by ScottieJ » Mon Jan 06, 2025 7:34 pm
If your gearbox crossmember is this style then yes a 1.3 gearbox will bolt straight in and the gear lever will be in the correct place.
Try to get yourself some 1.3 engine mounts cut off a 413/samurai chassis as it will make the job loads easier as well.
The ZukParts adapter kit from NZ is the best one to use.
ThomasSJ410
Post by ThomasSJ410 » Tue Jan 07, 2025 2:54 pm
Thanks for the advice this far. But i am wondering because of ease of access for myself, what about vitara engine mounts? I already have those. Or are the 413 ones preferable
Post by ScottieJ » Wed Jan 08, 2025 9:03 pm
You need the 1.3 mounts for the engine to sit in the correct position. Have a read of this thread viewtopic.php?t=9512
