shackles and bodylift question
Whats the difference?? i see bodylift kits are a lot more expensive than shackles (on ebay at least) but im not entirely sure what shackles do
Re: shackles and bodylift question
Shackles replace the originals(originals being shorter) and raise the chassis via the springs ....but there are more down sides to this lift method, they hinder your approach angles, flatten your leaf springs, dig in to terrain or can hit low rocks or stumps which does not feel very nice at all.......trust me in this case the cheaper option is not the best! If you haven't already viewed the diy page there is a section on how to make your own body lift. Alternatively you could do add a leaf......which simply is you add an extra leaf to your pack...these can be round £100 from llama.
Hope this helps.
Chris
Hope this helps.
Chris
my ride.........
my ride.........
ive got a shackle lift and would not recomend, as chris said + last time i tock it out i wrecked both front leafs, so im now goin for ad a leaf its not wot i want but its a good price, from llama 4x4
CRINGE
Stay away from the shackles, they can also throw your steering all over the shop as well as above reasons.
A body lift does just that, raises the body from the chassis via spacer blocks.
Ditch the shackle's Ive got them on mine and there awful!!! Just spent today making up new ones to lower it down!!!
Add a leafs
Body Lift
Lift springs
or virtual lift
Luke
Add a leafs
Body Lift
Lift springs
or virtual lift
Luke
