malie
Post
by malie » Wed Feb 17, 2010 6:20 am
hi..i just got another rusty SJ410 ( post the pic sum other tym havt take the pic yet )...
my problem is the steering box is jammed!!... can it be repair ?.. or can it replace with vitara steering box ?
malie
chan
Post
by chan » Wed Feb 17, 2010 10:36 am
hi there.
you can replace it with a vitara pas steering box but takes a bit of modding..
or just use an sj410 steering box?
- The Boss
Post
by ScottieJ » Wed Feb 17, 2010 12:49 pm
I think they are pretty simple so i would just take it off, strip it down and clean it all up, it's probably just leaked all it's oil and seized up.
malie
Post
by malie » Thu Feb 18, 2010 12:49 am
hi guys..
thnk for da reply
i took it off yesterday and strip it off, found out tiny little ball bearing fall out and the gear very rusty..try put WD-40 but the gear wont move...
thnk i need to change it but as you can see here at my place (brunei) searching for SJ part is slightly difficult,try to search for it anyway,wish me luck guy hehe..
Malie
- The Boss
Post
by ScottieJ » Thu Feb 18, 2010 11:00 am
fleave it to saok for a few days with a good coating of wd40 and it might free up
Post
by Tramp » Thu Feb 18, 2010 1:14 pm
scottiej410 wrote:fleave it to saok for a few days with a good coating of wd40 and it might free up
if the bearings have come out you will have trouble, i once set about rebuilding a steering box, but I couldnt get the seal for the input, it also needed a special tool to remove it, all the bearings are standard items so if the seal isn't shot and you can get the old seal out i can't see why you can't rebuild it,
Luke
