d86
Post
by d86 » Sun Mar 14, 2010 10:50 pm
ok then what is the easiest way to get all the sh*t out of my bonnet vent.
i really miss the heater now i have no top.
tony
- The Boss
Post
by ScottieJ » Mon Mar 15, 2010 10:30 am
I usually just blast it through with a jet hose as there are drain holes at each end of it.
(probably not the right way to go about it but ah well
Pugsley
Post
by Pugsley » Tue Mar 16, 2010 12:01 am
I have an old but very powerful "garage" vacuum cleaner - I tape a length of fuel tube of the correct diameter (a size that goes through the vent sections) to the suction nozzle being careful to cover up any air leaks. A bit time consuming as one bit of leaf etc will block the pipe but it will remove all the bits eventually.
The best mod I ever did was to bore a hole in the heater matrix cover to allow a vacuum nozzle to be inserted - the crud was amazing and its improved the heater efficiency no end.
mic
Post
by mic » Tue Mar 16, 2010 1:50 pm
d86
Post
by d86 » Tue Mar 16, 2010 7:28 pm
dont start mic i know i need one.
yes they would work a treat.
tony
Post
by ROBBIE » Sun Mar 21, 2010 5:09 pm
i put duct tape over the vent if i know its goin to get a bit dirty
just an idea for the future
Nasher
Post
by Nasher » Tue Jan 04, 2011 2:44 pm
mines full of sand and dirt and loads of fur tree bits? any ideas on how to get rid of all that?
Post
by Edweird » Tue Jan 04, 2011 6:24 pm
Mine just spits leaves out in your face when it feels like it.
dunk
- Recommended Trader
Post
by dunk » Tue Jan 04, 2011 10:59 pm
Back in the day when i had a heater i removed the recirc flap from inside the heater box so anything that fell through went onto the floor not all over the heater matrix.
