add a leafs
add a leafs
If I fit the add a leaf to my sj 410 do I need to fit longer shock absorbers or will the standard length be ok?
Which brand would be best to go for?
And are llama 4x4 the only company that do the add a leafs?
Re: add a leafs
hi standard shocks should be ok. dave at llama is great to do business with, bit chatty
Re: add a leafs
To maximise your leafs, longer shocks (1-2" will be needed)
You can buy shock extensions for the standard shocks
Re: add a leafs
henry, right im thinkin add a leafs just put the shape back but they do add lift aswell, i should know i have got them on mine
(in my defense im not feeling v well)
Re: add a leafs
ROBBIE wrote:henry, right im thinkin add a leafs just put the shape back but they do add lift aswell, i should know i have got them on mine![]()
What your saying is pretty much true, but in practice Its worth going for the +2" because as standard the leaves are pretty flat. so you end up putting more curve than normal
Re: add a leafs
Tramp wrote:ROBBIE wrote:henry, right im thinkin add a leafs just put the shape back but they do add lift aswell, i should know i have got them on mine![]()
Just adding to Luke, the fronts are flat as standard. The rears should have a curve on them. The add a leafs will effect the front more than the rear, but it will sit level. Beware, they are stiff
Re: add a leafs
Henry wrote:Tramp wrote:ROBBIE wrote:henry, right im thinkin add a leafs just put the shape back but they do add lift aswell, i should know i have got them on mine![]()
I was going to say that, but then I started thinking that sj's use the same size shockers front and back! so as back leaves are pre curved it wouldn't need the +2"..... but saying that I think the add a leafs give more curve than normal, so that would explain why you need the +2" on the back as well
Re: add a leafs
as i say not fellin well
an its me bday and im tired
Re: add a leafs
Ahh nice one
Thanks
Thanks
