Page 1 of 2
New Owner From Staffs
Posted: Tue Jun 28, 2011 11:21 am
by charger
Hello all I'm a new owner of an SJ 413 Samurai.
I also have a WJ anus that I have done a bit of off roading in but found the offroad parts like bumpers are very expensive so I stopped at a 2" lift & AT Tyres. Got the SJ so I could keep my anus in good condition & have a dedicated offroader. I plan on taking the SJ to my local pay & play to see how it does all stock. I live in Newcastle Under Lyme if any on else is anywhere near.
Re: New Owner From Staffs
Posted: Tue Jun 28, 2011 1:29 pm
Hi charger,
Welcome to Suzuki Club UK! Glad to hear you've got yourself an SJ! :D
Are you planning on having the zook road legal? If not, I'm sure a anus will be able to tow an SJ on a trailer!
If you are looking for other members, check out the members map. There should be a link above for it, with a spinning globe next to it.
I think we're mostly down south at the minute
Posted: Tue Jun 28, 2011 4:24 pm
by charger
Going to mod it but keep it street legal
Need help with mods what's cheapest way to lift will prop shaft be ok over 3" of lift what size tyres with stock & lift.
Posted: Tue Jun 28, 2011 4:30 pm
The cheapest way to lift is using lift shackles... but I will bet that none of our members will tell you to put them on!
They mess up your handling and ruin springs
The best cheap way off getting lift is using add-a-leaf springs.
They are an extra leaf that you put into your spring pack. It's a given that all SJ springs are probably much more flat than they should be, unless new springs have been fitted! Add a leaf will give you roughly 2" of lift.
You can do the whole vehicle for just over £100. If you're interested check out Llama 4x4 on our links page.
Dave from there is the nicest bloke ever so just phone him for a chat. It might take a while to get them from the states though.
If it's still not enough lift, you can add slightly extended shackles (no more than 1" and your springs/steering will be ok)
Just remember if you are lifting, you should also widen to retain stability. Getting some wheel spacers is the cheapest way.
You can either get them new from Bits 4 Vits, or get them from ebay
Posted: Tue Jun 28, 2011 8:01 pm
by ROBBIE
howdy :welcome: to the club. go add-a-leaf from llama as twiss said or get lift springs from the same place
and we need pics ;)
Posted: Tue Jun 28, 2011 8:55 pm
by dominic
Dom
:smokin:
Posted: Tue Jun 28, 2011 11:37 pm
:welcome: to :S:cuk matey :doublethumbs:
Well because it's me :mrgreen: and your saying it's just got to be a road legal toy that you can play in and not worry about too much.
I'm gonna ask can you weld? if so pull out the angle grinder and get cutting :mrgreen:,do a virtual lift and don't run any lift,(no shocks, propspacers or longer brakelines needed :thumbup:) just make sure you have some good leaf springs. add some 31x10.50 tyres on 8" wide rims and a rocklobster transfer box off rockwatt (you'll need a 410 and 413 tbox) to lower the gearing and you'll have a bloody capable and pretty reliable little SJ :mrgreen:
That's what I would do if I was to buy another one
this is what mine was like with virtual lift, a 2" spring lift and 33s. 33s brake more stuff than 31s though :lol:
Posted: Tue Jun 28, 2011 11:43 pm
by Newtomud
:redtin: Hi and :welcome: From Wolverhampton
Posted: Wed Jun 29, 2011 8:13 am
by charger
Thanks people
How does the SJ do stock off road
Will have a look at the Zuki section on llama, I know Dave bought a diff guard of him for the WJ
Posted: Wed Jun 29, 2011 9:05 am
Stock SJs are really good off road actually!
For ages I had mine standard with a set of 195 (regular size) mud tyres on it. It was awesome like that!
The problem arises when you get to some ruts dug by someone with bigger tyres... then you will ground out on your diffs/axles
