shackles!
mathewh11
shackles!
Post by mathewh11 » Mon Oct 24, 2011 7:36 pm
Hello!, :D does anyone know the standard lengh of them so i can make some out of my stupidly high ones! :argh: thankyou!!
Matt
Re: shackles!
Post by ScottieJ » Mon Oct 24, 2011 8:37 pm
I think it is 70mm? I'm not over at the workshop until tomorrow night so if no one confirms that between now and then ill measure them.
mathewh11
Re: shackles!
Post by mathewh11 » Mon Oct 24, 2011 8:41 pm
ledgend! :guns: , thanks alot mate doing them tommorow so hopefully someone will :D
matt
Re: shackles!
Post by ScottieJ » Mon Oct 24, 2011 9:04 pm
It shouldn't hurt to do them slightly longer like 90/100mm if you wanted. In fact it can give you a tiny bit more droop travel.
mathewh11
Re: shackles!
Post by mathewh11 » Tue Oct 25, 2011 7:35 pm
did them about 90mm in the end, but now i have another dilemma :er: . the rears have 3 leaves and a helper spring ive put the add a leaf under the 3 leaves and over the helper, however my front only has 3 and the bottom 1 is shorter than the add a leaf so i removed this and put the add a leaf in place is this correct?. also the back springs look like there gonna go higher than the front :S any advice please :D ill try put pics up later but i'm not promising anything :hahaha: thanks
matt
bigben
Re: shackles!
Post by bigben » Tue Oct 25, 2011 9:25 pm
did you do 90mm from hole to hole? im in your situation with the silly length shackles
mathewh11
Re: shackles!
Post by mathewh11 » Tue Oct 25, 2011 9:52 pm
bigben wrote:did you do 90mm from hole to hole? im in your situation with the silly length shackles
yes there still fairly long so just hoping it's gonna be ok :popcorn:
Re: shackles!
Post by twiss » Tue Oct 25, 2011 9:58 pm
I cut this:
to make this:
bigben
Re: shackles!
Post by bigben » Wed Oct 26, 2011 1:54 pm
ahh ace off to do mine now ill get some pics of it as i go
edit! ahh poo looks like mine are diffo i can probably only get them down 30mm currently sat at 140mm as there is a peice of box for strengthening in the middle unlike your thin rods. Could i cut the box out and use them at say 80mm withought the centre strengthening?
Sorry dont mean to hijack
bigben
Re: shackles!
Post by bigben » Fri Oct 28, 2011 1:43 pm
anyone? or shall i just put a bolt through the middle or weld it rigid
