Exhaust
charger
Exhaust
Post by charger » Mon Nov 21, 2011 9:57 pm
Is the stock SJ exhaust 1 piece from the muffler to headers or is there a separate back box going to the middle. Mine is blowing a bit & I wanted to put a cherry bomb on there. Does any one know if that is possible & if the cherry is ok with off road abuse.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: Exhaust
Post by ROBBIE » Mon Nov 21, 2011 10:02 pm
i do believe its 2 piece and a cherry bomb is fine to use i got middle and back cherry bombs and no problems
Re: Exhaust
Post by twiss » Thu Nov 24, 2011 9:36 am
I've got a cherry bomb on mine because the backbox pipe snapped in half...
I got a cherry bomb backbox (with a nice chrome tip), some pipe, and the flange off the original exhaust... weld it all together and hey presto!
charger
Re: Exhaust
Post by charger » Sat Dec 10, 2011 2:33 pm
Does anybody run a side exit for their exhaust??
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Re: Exhaust
Post by turbo-tom » Sat Dec 10, 2011 5:14 pm
charger wrote:Does anybody run a side exit for their exhaust??
i will hopefully be by next year 8-) 8-)
charger
Re: Exhaust
Post by charger » Sat Dec 10, 2011 6:40 pm
I'm thinking about a cherry bomb silencer coming out the side
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
justaddmud
Re: Exhaust
Post by justaddmud » Sat Dec 10, 2011 10:33 pm
I'm making my exhaust next week, single RC40 Exhaust box exiting just behing the drivers side door under the bed
and yes as everyone has said, there is a small box on the downpipe from the manifold, that then runs to a bigger silencer at the rear
I did do a cut and shut on project MK3 and substituted a peice of pipe, made very little difference, so i would imagine a cherry bomb would make a nice extra bit of noise
Re: Exhaust
Post by twiss » Sun Dec 11, 2011 9:24 pm
My cherry bomb sounds lovely and burbley... the bass noise is a bit intense inside the garage though!!
charger
Re: Exhaust
Post by charger » Mon Dec 12, 2011 8:36 am
Is a side exit ok for off roading?
I was thinking about cutting the middle pip down so it's pretty short then clamping the cherry to it.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Re: Exhaust
Post by ScottieJ » Mon Dec 12, 2011 8:44 am
Personally I wouldn't advise a side exit that exits below the sills, it will be more likely to get damaged. Behind the back wheel would be ok but that's awkward to do on an sj with the leaf springs.
