help please
mayhemmiller
help please
Post by mayhemmiller » Tue Nov 22, 2011 6:35 pm
i know this is a little long in coming
traveling back to france a few weeks ago i get into france 20 mins off the boat and the engine dies on me i call for brakedown rescue and they tell me that the fuel pump is gone so 24 hrs latter i return home on the back of a lorry (pictures to follow soon)
so befor i spend a lot of time/money any thoughts or suggestions on what could be wrong
awaiting the next adventure
:mayhemmiller:
Re: help please
Post by ScottieJ » Tue Nov 22, 2011 7:11 pm
Well its a mechanical pump so once its gone it needs replacing. Have you checked it yourself? Undo the carb fuel in pipe and turn the engine over to see if it squirts fuel?
Try that and report back with your findings :doublethumbs:
mayhemmiller
Re: help please
Post by mayhemmiller » Tue Nov 22, 2011 7:19 pm
yeah tried that no fuel coming through
:mayhemmiller:
Re: help please
Post by Tramp » Tue Nov 22, 2011 7:20 pm
Fuel pumps aren't expensive to replace and are easy to do! I say if there is any doubt about it, replace it
Re: help please
Post by ScottieJ » Tue Nov 22, 2011 7:22 pm
Yeah head to a motor factors and get a new one its the sort of thing that I wouldn't bother with second hand
mayhemmiller
Re: help please
Post by mayhemmiller » Tue Nov 22, 2011 7:31 pm
thanks will get my sister to try the local motor factors ohh the joys of being in france
:mayhemmiller:
mayhemmiller
Re: help please
Post by mayhemmiller » Tue Nov 22, 2011 8:19 pm
just opened up the fuel pump is the bottom half ment to be full of oil ?
any idea on a part number for the pump
:mayhemmiller:
Re: help please
Post by dan_2k_uk » Tue Nov 22, 2011 8:29 pm
Yeah there is oil in the bottom to lube the mechanism. There should be a lever tgat gets pushed by a rod that goes into the head.
Dan
rgonzobull
Re: help please
Post by rgonzobull » Tue Nov 22, 2011 9:53 pm
Check there is fuel getting to the pump. It wont be the first time someone has put an inline fuel filter in and thats whats blocked. Worth checking fuel is getting to the pump before blaming pump
LJ80Q
Re: help please
Post by ScottieJ » Wed Nov 23, 2011 9:30 am
That's a good call that, they do usually cause a bit of stuttering before restricting all the flow but its worth checking.
