sammy axles on 410
nathan.stevens
sammy axles on 410
Post by nathan.stevens » Sun Jan 01, 2012 8:08 pm
is it possible to put samurai axles on a 410? if so what work is involved?
in my mind, it's just cut the spring perches off the axles, then weld new ones in, just slightly narrower so they line up with the 410 spring mounts.
am i right or have i got it completely wrong, and does anyone else have this setup?
cheers, nathan
Re: sammy axles on 410
Post by turbo-tom » Sun Jan 01, 2012 8:12 pm
not sure what work is involved but i know the sammy axles are wider for sure ;)
i believe scott is doing this mod ;)
nathan.stevens
Post by nathan.stevens » Sun Jan 01, 2012 8:14 pm
yeah i know they're a bit wider, would be ideal for me to make it a bit more "stable" as it's my daily.
im sure i read a post before from scott with the measurements etc but for the life of me i can't find it!
Post by ScottieJ » Mon Jan 02, 2012 12:17 am
This thread you mean? http://www.suzukiclubuk.co.uk/phpBB3/ph ... =12&t=2801" onclick="window.open(this.href);return false; its in the stickies at the top of this section ;)
It's pretty much just a case of carefully cutting the old perches off and moving them in to match the 410 spring width.
Remember to keep the perches at the same angle they were originally so that you don't mess up your driveshaft angles or caster angle.
nathan.stevens
Post by nathan.stevens » Mon Jan 02, 2012 3:20 pm
yeah that's the one, thanks mate!
my tax runs out end of the month and MOT in june so i might put my pajero on the road and do a load of jobs on the SJ to get it how i want it for next winter.
Post by Darrell » Mon Jan 02, 2012 7:19 pm
No that's illegal. The law clearly states that suzuki SJ's must be fixed/modified as soon as possible.. :thumbup:
Post by ScottieJ » Mon Jan 02, 2012 8:02 pm
Darrell wrote:No that's illegal. The law clearly states that suzuki SJ's must be fixed/modified as soon as possible.. :thumbup:
:guns:
Team Pink
Post by Team Pink » Mon Jan 02, 2012 9:19 pm
To make sure you get the angles right do one at a time. Clamp a straight edge to the original one and a straight edge to the one you have cut off. Eye up the two edges and get them in line and the angles will be correct. Then use the "new" one to align the "old" one after you have cut it off
Tim
Post by ROBBIE » Tue Jan 03, 2012 9:28 am
:guns:
how long has it been in the workshop now Scottie?? :lol:
Post by ScottieJ » Tue Jan 03, 2012 9:49 am
ROBBIE wrote:
:guns:
It's being modified therefore I am not breaking the law :thefinger:
errrrr about 14-15months :lol:
Back on topic there is also this method to keep them in the correct position
http://translate.google.com/translate?s ... 47&act=url" onclick="window.open(this.href);return false;
