Rear diff seal
Turb()
Rear diff seal
Post by Turb() » Sun Jan 22, 2012 5:47 pm
Hi,
I think the seal is knackered on my rear diff. There is some oil leaking out where the prop goes in...
How much are they to replace and are they easy to do?
Re: Rear diff seal
Post by Darrell » Sun Jan 22, 2012 7:16 pm
Seals not very pricey but the jobs a bitch if you do it properly. New crush collar, loads of setting up. If it's only leaking a little I would check the vent/breather is not blocked and just top it up now and again. I've not changed one but have read a lot about setting it back up :thumbdown:
Turb()
Re: Rear diff seal
Post by Turb() » Sun Jan 22, 2012 9:45 pm
ok, I will check the breather first. Hope that solves it! Chance would be a fine thing XD
Re: Rear diff seal
Post by ScottieJ » Sun Jan 22, 2012 10:32 pm
Is there any play in the pinion bearing? I.e. can you move the flange from side to side, In or out?
