1994 suzuki samurai no spark
jgp1986
Post by jgp1986 » Fri Feb 10, 2012 12:47 pm
ive been havin problems gettin my truck to start, ive recently fitted a su carb and now for some reason when ive come to start it up ive got no spark
ive checked wires are connected but not sure what it could be, do these have any sort of ecu of any kind and where would it be located, its got a clifford alarm on it but never had a fob since i brought it so think thats inactive
help me please :thumbdown:
Re: 1994 suzuki samurai no spark
Post by ScottieJ » Fri Feb 10, 2012 12:53 pm
did your SJ originally have single point injection? if so there will be an ecu.
jgp1986
Post by jgp1986 » Fri Feb 10, 2012 1:36 pm
it was originally on a aisan carb mate.
Highlander
Post by Highlander » Fri Feb 10, 2012 1:50 pm
No spark at the plugs?
trace it back through the leads, distributer cap, rotor arm, ht lead ,coil etc till you find where the spark starts/stops
Post by ScottieJ » Fri Feb 10, 2012 2:08 pm
Do you have power at the coil?
jgp1986
Post by jgp1986 » Fri Feb 10, 2012 3:13 pm
yes ive solved it a wire was off the coil but still looked like it was conected but thats where the power trail ended so found it, but now ive got it runnin im havin problems with the su carb its sparying petrol out of everywhere?
Ive followed the tutorials and ive got the fuel overflow running down to the floor but theres another pipe comin out below it, its runs just its over flowing with fuel is the one thats directly under the over a return??
Post by twiss » Fri Feb 10, 2012 3:37 pm
Can you upload a pic of that side of the carb?
Most of the time the SUs have 3 pipes on the fuel intake side.
1. Fuel in
2. Fuel overflow
3. Breather (should be blocked)
There are some SUs though that have more pipes than that!
jgp1986
Post by jgp1986 » Fri Feb 10, 2012 4:17 pm
ive not got a pic but ill find one now on internet of the same carb if that will do
jgp1986
Post by jgp1986 » Fri Feb 10, 2012 4:34 pm
http://www.miniaustindrome.com/t105-car ... es-minimum
thats the carb im tryin to use at the top of the page
its coming out the 2 pipe inline with each other the over flow n one blow it, could the float be stuck do u think causing this?
****PROBLEM SOLVED**** there was no float needle in the carb plus its a hif38 bought a hif44 now to replace it with!
