spring over axle
adamsj
spring over axle
Post by adamsj » Mon May 28, 2012 9:58 pm
Wen u do spring over axle do u have to angle the axle upwards more.if that makes sense
Re: spring over axle
Post by ScottieJ » Tue May 29, 2012 9:41 am
No! This is a common mistake people make.
It destroys the caster angle on the front axle.
On the rear UJs on the propshaft will no longer be in phase and will fail prematurely.
Weld the new SPOA perches on parallel to the existing SPUA perches. :doublethumbs:
Highlander
Post by Highlander » Tue May 29, 2012 9:47 am
Angle the diff upwards to reduce the angle on the prop/ujs?
No, especially not on the front, it'll throw your steering geometry out.
Post by ROBBIE » Tue May 29, 2012 10:29 am
dont do sprig over nasty mod imo
Highlander
Post by Highlander » Tue May 29, 2012 10:47 am
Great ground clearance for off road though :D
adamsj
Post by adamsj » Tue May 29, 2012 3:24 pm
Cheers.that mite b why the axles that r on it r nakerd
