I'm going with the Merc steering arms and TRE's
Been trawling the Merc forums to find the right ones, the off road forums are full of dodgy info!
They are actually called steering arms and are fitted to the 126 Chassis which covers these models :
Model numbers in
BOLD
Part 11 on this picture (they are handed left and right)
These are the Mercedes part no's (if you want new ones)
STEERING ARM LEFT - A 1163321620
STEERING ARM RIGHT - A 1163321720
This is one fitted on a Suzuki, it bolts to the caliper holes but needs slightly drilled out to fit and longer bolts.
The new bolts need to be :
M12 x 1.25 x 50
M12 x 1.25 x 60
They are different lengths, you will need one of each for either calliper
I'll add some pics as I do it
