extendable shackles
adamsj
extendable shackles
Post by adamsj » Sun Jun 17, 2012 12:00 am
has anybody seen the extendable shackles on ebay.has any body used them or similar 1s,are they good or not
Re: extendable shackles
Post by ScottieJ » Sun Jun 17, 2012 8:44 pm
I personally wouldn't bother with them but thats just me.
adamsj
Post by adamsj » Sun Jun 17, 2012 9:53 pm
Why
Post by twiss » Mon Jun 18, 2012 11:28 am
First off, they can make your truck less stable on side slopes.
If you are leaning off to one side and the shackles on the high side extend, you're gonna end up on your roof!!! ;)
Also, it may give the impression of more articulation as it allows the axle to droop down.
The problem is, there is no car weight over the wheel, just the weight of the wheel itself. Even if your wheel is touching the ground with the shackles extended, it probably won't give you any more grip!
I definitely wouldn't use them on the road!
