Firstly I made the rookie mistake of having the dizzy 180 degrees out but found out pretty quickly. Kept turning it over and over and eventually it fired up
I have no throttle cable mounted yet so was doing it by hand using the choke for now, but Ive made a bracket, just needs a bit of fettling to clear various things but that should be sorted in the morning
Also, initially the starter worked perfectly then after a few more turn-overs it was making some dodgy noises when cranking, and I could hear it "winding down" once I'd let go of the key until eventually it wasnt meshing at all with the flywheel and was just spinning over. The starter is pretty tight up against the block despite being a "skinny" one but would JUST fit with a little shove.
It was also very tight to remove despite revolving when the mounting bolts were out......so my theory is that because its so tight its not quite sitting right and therefore not meshing correctly. In which case I will take a little bit of metal off of the offending area tomorrow. Does this sound likely?
All teeth are still on both it and the flywheel btw
