Front differential pinion oil seal
firemansam
Post by firemansam » Wed Apr 08, 2009 6:54 pm
Is it possible to change the oil seal on the differential pinion (the input shaft) without removing the entire differential assembly?
mine's sprung a leak and ive got to go away on the weekend, a long drive.
anybody changed the oil seal?
bourneyo
Re: Front differential pinion oil seal
Post by bourneyo » Thu Apr 09, 2009 10:42 am
Yea it can be done, remove the prop, and on the flange there is a 27mm (I think) nut undo it take the flange off and the oil seal should be just behind it prize it out, then put abit of gear oil round the outside of the new one and gently tap it into place, replace the flange and nut.
you are supposed to have that 27mm nut set to a certain torque and have a new crush collar put it on the inside of your diff otherwise it can offset the internals of your diff reducing its life, but when I did mine i didn't bother and touch wood it hasn't gone bang yet.
It may help if you can get a impact gun on the nut as it is bloody tight or just a big breaker bar. keep the wheels on the ground otherwse the wheels will just spin when you attack the nut but keep the SJ well chocked otherwise it will run you over!
Dan 8-)
firemansam
Post by firemansam » Fri Apr 10, 2009 11:23 pm
sorted! thanks bourneyo
was a pain trying to undo the flange nut though
sometimes i wish i could tip my zook on its side...
ahh well dream on eh?
Sam
muddy kev
Post by muddy kev » Sun Oct 11, 2009 1:32 pm
hi, does any 1 know where the best place 2 get the seal from? is it main dealer part only? can't seem to find them any where else.
cheers kev
Henry
Post by Henry » Sun Oct 11, 2009 2:25 pm
If its for a sammy
Part number 09283-40027
Description seal
Price £6.68 + VAT
muddy kev
Post by muddy kev » Sun Oct 11, 2009 3:14 pm
thanks henry.
bourneyo
Post by bourneyo » Sun Oct 11, 2009 10:19 pm
I was waiting ages for the seal from main dealer, and they never did come through with the goods, I went to KAP payed waaaaay over the ods but it arrived prity soon and i was desperate.
Dan 8-)
Henry
Post by Henry » Sun Oct 11, 2009 10:24 pm
I think it depends what dealer you go to in a situation like that. My local main dealer (Chester) are robbing gets, but they do have them when you want them. :twisted:
muddy kev
Post by muddy kev » Mon Oct 12, 2009 8:11 pm
ordered seal today, dealer said be in in morning. £8.50 sounds good to me. they also said that its the same seal for all the suzuki jeeps front and rear.
