charger
Post
by charger » Wed Aug 29, 2012 12:44 pm
I'm slightly taller in the rear can I put extended shackles on just the front to level it up?
I'm running the add a leaf all round with the helper leafs in the rear.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
- The Boss
Post
by ScottieJ » Wed Aug 29, 2012 12:55 pm
I'd try pulling the add-a-leafs from the rear to see if it levels out, should also soften the suspension up nicely.
charger
Post
by charger » Wed Aug 29, 2012 1:11 pm
ScottieJ wrote:I'd try pulling the add-a-leafs from the rear to see if it levels out, should also soften the suspension up nicely.
Can this this be done without undoing any bolts?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
- SCUK is my life
Post
by andyrew » Thu Aug 30, 2012 7:41 pm
[/quote]
Can this this be done without undoing any bolts?[/quote]
No,
are the front springs knackered? with the add a leafs fitted to my dead springs , the top springs where bending down either end of the add a leaf spring. in an "M" kind of shape.
