Longer shocks / modded shock mounts?
Post by Jordi » Thu Dec 27, 2012 9:09 am
I'm currently on fitting +1.5" springs and having done one have come across the issue of the shocks being too short. Rear shock on full extent doesnt reach between the mounts.
Whats the best way to measure up for new shocks?
Re: Longer shocks / modded shock mounts?
Post by ScottieJ » Thu Dec 27, 2012 10:14 am
Make sure your bumpstops are fitted and set to the height that you'll be running them. then flex it up to the point it lifts a wheel on each corner. measure between the upper and lower shock mounts at each corner then -1to2" off the compressed length and + a few inches to the extended length.
