lift kit and shocks help needed
duncslow
Post by duncslow » Sat Feb 16, 2013 5:18 pm
help needed please. Today I have fitted a 2" shackle lift on my 410 santana and during fitting I realised that the shocks dont extend enough and I have had to bend the spring eye down to get the bolts in. I have read that astra shocks are an option and have seen these on evil bay. opinions needed guys
http://www.ebay.co.uk/itm/Anschler-Rear ... 4d014ab9d5
regards Chris
Re: lift kit and shocks help needed
Post by ScottieJ » Sat Feb 16, 2013 9:19 pm
I know you probably don't want to hear this but personally to solve the problem I would just put the standard shackles back on, lift shackles have more negatives than plus points when used with standard springs and will actually make your Sj handle worse on road and perform worse off road.
duncslow
Post by duncslow » Sat Feb 16, 2013 9:41 pm
Thanks for the input, but I need the lift to help the sump clear as its a vit engine. Also the lift ideas are numerous and confusing to me being new to the scene. I cant seem to get my head round the differences and types of conversions and I also need to keep within some sort of budget. do you have any reasonably easy ideas for me to try that isnt going to break the bank and doesnt need a degree in engineering
Regards Chris
Post by Jordi » Sat Feb 16, 2013 9:44 pm
Could fit a 1.3 sump?
dunnin21
Post by dunnin21 » Sat Feb 16, 2013 9:46 pm
Whats in involved in fitting a 1.3 sump, is it a case of new gasket and bolt up
Post by Edweird » Sat Feb 16, 2013 9:47 pm
dunnin21 wrote:Whats in involved in fitting a 1.3 sump, is it a case of new gasket and bolt up
I believe so. It's essentially the same block.
Post by Jordi » Sat Feb 16, 2013 10:41 pm
Oil pick up requires making a bit shorter too.
Post by donkeychomp » Sat Feb 16, 2013 10:46 pm
With lift shackles you can get shock relocation kits, I used that on my old 410...flea bay has some.
