Tie Rod
Famerbennie
Tie Rod
Post by Famerbennie » Sat Apr 13, 2013 6:36 pm
Thinking Of Putting Sammi Axles On My 410 Can I use My Existing Tie Rod Or Not?
Re: Tie Rod
Post by andyrew » Sat Apr 13, 2013 6:44 pm
The tie bar between the two swivels is different on the 410.
You will need a samurai one. If you dont have on I have one available.
Famerbennie
Re: Tie Rod
Post by Famerbennie » Sun Apr 14, 2013 3:10 pm
apart from the length any other differences?
Famerbennie
Re: Tie Rod
Post by Famerbennie » Mon Apr 22, 2013 8:53 pm
so could i just stretch a 413 tie bar or not?
Re: Tie Rod
Post by ScottieJ » Mon Apr 22, 2013 10:46 pm
You could but technically it should be an MOT fail as you are not allowed to re-weld or apply excessive heat to steering components.
Re: Tie Rod
Post by Darrell » Mon Apr 22, 2013 11:09 pm
And you would need to extend the drag link. :thumbdown:
