Can I replace front crank seal without removing engine?
npjrogers@btinternet.com
Post by npjrogers@btinternet.com » Wed May 22, 2013 10:19 am
Um.. The title says it all..I would like to see if my 'sump' oil leak is in fact a leaking front crankshaft seal that is showing just fwd of the oil filter.
Nick
Belfast
Re: Can I replace front crank seal without removing engine?
Post by ScottieJ » Wed May 22, 2013 12:39 pm
yes you can but it might be quite awkward :thumbup:
ferris
Post by ferris » Wed May 22, 2013 5:33 pm
I changed the one on my SJ without removing the engine. I did have to take the radiator out tho.
Post by ScottieJ » Wed May 22, 2013 6:27 pm
There is more space on the front of an SJ for access but I'm sure it can be done.
Gotta make sure you get that crank pulley bolt torqued up properly again when you do it though :thumbup:
