From Sj to jimny help ??
Right guys iv decide on getting a jimny instead of my beloved Sj. Question is what parts can I use from Sj that will be compatible for jimny. I no I can use freewheeling hubs, steering damper, possibly shocks ? Also is the 413 transfer box useable.thanks in advance Andy
Re: From Sj to jimny help ??
Transfer box is. Not sure if it is a bolt on swap but SJ boxes are much stronger.
You need an adapter kit for the transfer box, Rockwatt makes them
Ok thanks are the shocks useable, just iv just bough a set of rough country
Shocks should be, my back back ones came off a jimny and the fronts look the same.
