rear leaf springs
jonny griff
rear leaf springs
Post by jonny griff » Mon Jun 08, 2009 9:01 pm
hiya all just would like to know if you could help, me iv just bust my off side rear leaf spring on my sj410 and am just looking for a cheap replacement or if you know af any other springs that would fit without any mods i would lie to keep this repair as cheap as poss due to most of my cash is geting pumped into my samurai thanx for your help jonny
4x4 pics 021.jpg (100.7 KiB) Viewed 4485 times
Henry
Re: rear leaf springs
Post by Henry » Mon Jun 08, 2009 9:06 pm
Have you only got 1 leaf on the front? If so parabolic's i think :|
Be lucky to find some!
muddy kev
Post by muddy kev » Tue Jun 09, 2009 9:34 am
hi, bedford rascal rear springs fit but u will have to change both sides as it will give u about 1.5 to 2 inch's of lift over old standard springs. u will need to change the front bush's as well. if your rear bush's r ok they should fit. but the front bush is larger, i made up some nylon 1's.
also cut off the small metal stop just in front of the rear hanger.
i got mine off of ebay £22 per spring, i broke an iron man spring on mine and the rascal springs had about the same lift but were a 1/4 of the price.
cheers kev
